Testpagina Plaatjesserver2
Testen van links naar plaatjesserver
Via span:
Via link met aanvulling:
Via tabel:
Volgnr = 01
Relaiskast
Foto gemaakt door: Klaas Zondervan
Via sjabloon:
Relaiskast
Instellingen:
$wgAllowExternalImages
When set to true, users can bring in an inline image from an external URL. They do this simply by sticking the full URL into the wiki text (without any other surrounding markup being required) That is the direct URL to an image resource on another website. When set to false, the full URL appears as a text link to the image.
Note that if you want to allow images from a single trusted source (e.g. from within your own domain) then set this to false, and use
$wgAllowExternalImagesFrom.
Extensie:
MediaWiki will only recognize image URLs with image file extensions; you may need to add a 'fake' parameter to the end of some URLs, like "&junk=junk.png" or "?.png" to force the parser to realize the Image_URL actually points to an image, so that it will embed it.
Onderschrift:
You cannot easily put image caption for external images. One solution might be using table.
|image url
|caption
Meer info Afbeeldingen Style Afmetingen plaatjes
EDIT
