MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
list=allusers (au)
(main | query | allusers)
  • Voor deze module zijn leesrechten nodig.
  • Source: MediaWiki
  • License: GPL-2.0+
Enumerate all registered users.
Parameters:
aufrom
The user name to start enumerating from.
auto
The user name to stop enumerating at.
auprefix
Search for all users that begin with this value.
audir
Direction to sort in.
One of the following values: ascending, descending
Standaard: ascending
augroup
Only include users in the given groups.
Values (separate with | or alternative): bot, sysop, bureaucrat, gebruikers, superusers
auexcludegroup
Sluit gebruikers in de gegeven groepen uit.
aurights
Only include users with the given rights. Does not include rights granted by implicit or auto-promoted groups like *, user, or autoconfirmed.
Values (separate with | or alternative): apihighlimits, applychangetags, autoconfirmed, autocreateaccount, autopatrol, bigdelete, block, blockemail, bot, browsearchive, changetags, createaccount, createpage, createtalk, delete, deletechangetags, deletedhistory, deletedtext, deletelogentry, deleterevision, edit, editcontentmodel, editinterface, editprotected, editmyoptions, editmyprivateinfo, editmyusercss, editmyuserjs, editmywatchlist, editsemiprotected, editusercss, edituserjs, hideuser, import, importupload, ipblock-exempt, managechangetags, markbotedits, mergehistory, minoredit, move, movefile, move-categorypages, move-rootuserpages, move-subpages, nominornewtalk, noratelimit, override-export-depth, pagelang, patrol, patrolmarks, protect, purge, read, reupload, reupload-own, reupload-shared, rollback, sendemail, siteadmin, suppressionlog, suppressredirect, suppressrevision, unblockself, undelete, unwatchedpages, upload, upload_by_url, userrights, userrights-interwiki, viewmyprivateinfo, viewmywatchlist, viewsuppressed, writeapi, renameuser
Maximum number of values is 50 (500 for bots).
auprop
Which pieces of information to include:
blockinfo
Voegt informatie over een actuale blokkade van de gebruiker toe.
groups
Toont de groepen waar de gebruiker in zit. Dit gebruikt meer serverbronnen en kan minder resultaten teruggeven dat de opgegeven limiet.
implicitgroups
Toon alle groepen de gebruiker automatisch in zit.
rights
Toon de rechten die de gebruiker heeft.
editcount
Voegt het aantal bewerkingen van de gebruiker toe.
registration
Voegt de registratiedatum van de gebruiker toe, indien beschikbaar (kan leeg zijn).
centralids
Adds the central IDs and attachment status for the user.
Values (separate with | or alternative): blockinfo, groups, implicitgroups, rights, editcount, registration, centralids
aulimit
How many total user names to return.
No more than 500 (5.000 for bots) allowed.
Type: integer or max
Standaard: 10
auwitheditsonly
Toon alleen gebruikers die bewerkingen hebben gemaakt.
Type: boolean (details)
auactiveusers
Toon alleen gebruikers die actief zijn geweest in de laatste 30 dagen.
auattachedwiki
With auprop=centralids, also indicate whether the user is attached with the wiki identified by this ID.
