MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
action=userrights
(main | userrights)
  • Voor deze module zijn leesrechten nodig.
  • Voor deze module zijn schrijfrechten nodig.
  • This module only accepts POST requests.
  • Source: MediaWiki
  • License: GPL-2.0+
Change a user's group membership.
Parameters:
user
User name.
Type: user name
userid
User ID.
Type: integer
add
Add the user to these groups, or if they are already a member, update the expiry of their membership in that group.
Values (separate with | or alternative): bot, sysop, bureaucrat, gebruikers, superusers
expiry
Expiry timestamps. May be relative (e.g. 5 months or 2 weeks) or absolute (e.g. 2014-09-18T12:34:56Z). If only one timestamp is set, it will be used for all groups passed to the add parameter. Use infinite, indefinite, infinity, or never for a never-expiring user group.
Separate values with | or alternative. Maximum number of values is 50 (500 for bots).
Standaard: infinite
remove
Remove the user from these groups.
reason
Reason for the change.
Default: (empty)
token
A "userrights" token retrieved from action=query&meta=tokens
For compatibility, the token used in the web UI is also accepted.
This parameter is required.
tags
Change tags to apply to the entry in the user rights log.
Voorbeelden:
Add user FooBot to group bot, and remove from groups sysop and bureaucrat.
api.php?action=userrights&user=FooBot&add=bot&remove=sysop|bureaucrat&token=123ABC [open in sandbox]
Add the user with ID 123 to group bot, and remove from groups sysop and bureaucrat.
api.php?action=userrights&userid=123&add=bot&remove=sysop|bureaucrat&token=123ABC [open in sandbox]
Add user SometimeSysop to group sysop for 1 month.
api.php?action=userrights&user=SometimeSysop&add=sysop&expiry=1%20month&token=123ABC [open in sandbox]
